Raijintek Orcus 360 AIO Review
It’s fair to say that when we get a 360mm AIO land on our doorstep here at OC3D towers, we get more than a little bit “Fizzy” in the underpants department. The reason for this adolescent “Fizziness” is that although 280mm AIOs are great, there’s always a good chance that a 360mm rad based unit will claim the torture test crown. So what have we here then? Well, with a thin rad, quiet fans and full RGB integration, including remote control, the Orcus from Raijintek certainly ticks a lot of boxes. The question is, how will it perform? For a bit of a hint, let’s take a look at those all important Technical Specifications shall we.
| Material | Aluminium Radiator, Copper Contact Plate |
| Tubing | 5mm/10.6mm Teflon coated |
| Dimensions | 395x120x28mm (LxWxD) |
| Intel | 775/115x/1366/201x/2066 CPU (Core™ i3 / i5 / i7 / i9 |
| AMD | AM4/AM3+/AM3/AM2+/AM2/FM2+/FM2 |
| Fans | 3x120mm @ 800-1800rpm |
| AirFlow | 42.17CFM |
| Static Pressure | 1.7mmH20 |
| Noise | 23dB(A) |
Key Features
Boy do Raijintek need to get themselves a better translator and Proof reader
- Best performing, most user friendly and most spot light catch , an AIO liquid cooling system at market
- All-In-One liquid CPU cooler with external PUMP, copper Water block and Rotating Blade with RGB light
- New design and External Pump with high Q-max (66 L/H) and no vibration incurred on M/B and CPU
- Durable and reliable PUMP Bearing type – Ceramic axis
- Copper water block by micro channel, extra large contact fin area with multiple channels to provide best flow of liquid
- Cooling fan system with 12025 RGB PWM fans, 8 port control hub and remote controller
- 8port Control hub with switch of “M/B ; Remote” to provide most usage of RGB lighting control
- Rotating Blade design with RGB LED inside tank to show water flow and indicates the coolant level
- 3pcs performing 12025 PWM fans with RGB lighting
- Specific 11 fan blade design and 8pcs Anti-vibration rubbers
