ASUS X570 Crosshair VIII Formula Review
Please note this review was written prior to the AGESA 1001 BIOS update. Our graphs have been updated to reflect the new results, but the text remains the same as the fast single threaded stock performance affects so few of our results and none of our overall opinion.
The first X570 motherboard we tested was the excellent Crosshair VIII Hero. The Crosshair range is very much ASUS applying their ROG skills to the AMD platform, and with the Hero it combines an excellent feature set with impressive looks at an affordable price.
Like anything though, there is always room in the range for a take upon the, if you’ll pardon the expression, formula that includes more premium features and accoutrements for the more discerning enthusiast, or at least the ones with a larger budget. The ROG Formula has always been a popular choice, having very nearly the same high end features as the extreme – for example the Rampage Formula vs Rampage Extreme – but without quite hitting the flagship price point. Knowing that the Crosshair VIII Hero was very good we couldn’t wait to discover what the Crosshair VIII Formula has up its sleeve and how far it could push our Ryzen 9 3900X.
As a slight aside we want to thank you for your patience in waiting for the next batch of X570 reviews. Sometimes personal emergencies happen which delay us bringing you things in as timely a manner as either we’d like or you’d expect. Without further ado, let’s get down to business.
Technical Specification
The Crosshair VIII Formula sports a wide selection of high end elements befitting of a Republic of Gamers branded product. We have the pre-mounted IO shield that has saved all our fingertips from cuts, the SupremeFX audio which utilises the ubiquitous ESS ES9023P DAC dripping honey into your ears, as well as the PCI Express 4.0 slots that are such a headline feature of the X570 Chipset. Anything which can save us having to decide between graphical splendour and fast M.2 drives has to be applauded and the addition of the monster bandwidth from the PCI Express 4.0 format definitely does that. With the right Ryzen 3 CPU installed there are x16 PCI Express 4.0 slots for all your needs. Even with an older CPU the chipset can support 1 running at x4. We also have 12 USB 3.2 ports split between eight Gen2 and four Gen1, with one of them being the easy Type-C and the others being the “it goes in the third way round” Type-A.
The ASUS LiveDash OLED display was a huge success on their preceding ROG models so it is no surprise to see it included on this premium X570 motherboard. They really have pulled out all the stops here. Additionally there is plenty of built in RGB lighting so even those of you who haven’t yet indulged in a RGB LED strip can enjoy picking your own preference of hue. Having speed without protection is pointless and so to this end the Crosshair VIII Formula has ESD guards on the back connectors, bracing on the PCI Express slots and even, as we’ll see on the next page, extra bracing around the 12V CPU power input.
We’ll look at the factory installed EK CrossChill III in more detail on the next page, but even before that it’s clear that it helps harmonise the aesthetics of the Crosshair. Next up is the all important AM4 socket ready for the Ryzen 3 CPUs that will be launched – and reviewed here at OC3D – on the same day as the X570 itself. There are lots of Front Panel USB options too if you want to festoon your chassis with ALL the USB ports, whilst for those of us who can’t afford M.2 drives there are eight 6 Gb/s SATA ports. If you are fortunate enough to have a M.2 drive you’ll be pleased that there are 2 slots on the Crosshair VIII Formula.
Lastly before we look at the Crosshair VIII Formula in the flesh we find six PWM/DC fan headers, a 12V water pump header and flow monitor and of course the AIO pump header too. If you have a hybrid GPU there is a well placed header just above the first PCI Express slot too. In short, if you want your system to have good airflow the Crosshair has enough to keep you happy.
