ASUS Z790-A Prime WiFi Review
Test Setup
Intel Core i9-13900K
G.Skill Trident Z5 Neo 4800 32GB
Nvidia RTX 2080 Ti
Sabrent Rocket 2TB
Corsair 5000T
Corsair RM1000i
Corsair H170i 420
Windows 11
Clock Speeds
We primarily used the Z790-A Prime as the test bed for our DDR4 vs DDR5 review, which you can also read on these pages. Rather than push the 60A power stage too harshly with the demands of the Core i9-13900K, it is instead run at stock. Although, as you’ve seen so far in our coverage of the Intel 13th Generation launch, stock just means the CPU boosts itself, so it’s still a good demonstation of the motherboard’s prowess.
