Gigabyte EP45-DS3P (P45) DDR2 Motherboard
Hailing from the Premiership of PC manufacturers, Gigabyte are synonymous with PC builders worldwide. Renowned for the use of quality components and excellent reliability it comes as no surprise that Gigabyte are usually one of the first manufacturers mentioned when anyone recommends a new motherboard. So when they asked us to review their latest P45 release we jumped at the opportunity. We have extensively covered the features of Intels P45 chipset in previous reviews so can Gigabyte bring anything new to the table? Lets take a look :
- Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/Intel® Core™ 2 Duo processor/ Intel® Pentium® Dual-Core processor/Intel® Celeron® processor in the LGA 775 package
- L2 cache varies with CPU
Front Side Bus
- 1600/1333/1066/800 MHz FSB
Chipset
- North Bridge: Intel® P45 Express Chipset
- South Bridge: Intel® ICH10R
Memory
- 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory
- Dual channel memory architecture
- Support for DDR2 1200/1066/800/667 MHz memory modules
(Refer to Memory support list for more information)
Audio
- Realtek ALC889A codec
- High Definition Audio
- 2/4/5.1/7.1-channel
- Support for Dolby Home Theater
- Support for S/PDIF In/Out
- Support for CD In
LAN
- 2 x Realtek 8111C chips (10/100/1000 Mbit)
- Support for Teaming
Expansion Slots
- 1 x PCI Express x16 slot, running at x16
- 1 x PCI Express x16 slot, running at x8
(The PCIEx16 and PCIEx8 slots support ATI CrossFireX technology and conform to PCI Express 2.0 standard.) - 1 x PCI Express x4 slot
- 3 x PCI Express x1 slot
- 1 x PCI slots
Storage InterfaceSouth Bridge:
- 6 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3, SATAII4, SATAII5) supporting up to 6 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
iTE IT8213 chip:
- 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
iTE IT8720 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394a
- T.I. TSB43AB23 chip
- Up to 3 IEEE 1394a ports
(2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB
- Integrated in the South Bridge
- Up to 12 USB 2.0/1.1 ports
(8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
- 1 x 24-pin ATX main power connector
- 1 x 8-pin ATX 12V power connector
- 1 x IDE connector
- 1 x CPU fan header
- 3 x system fan headers
- 1 x power fan header
- 1 x North Bridge fan header
- 1 x front panel header
- 1 x front panel audio header
- 1 x CD In connector
- 1 x S/PDIF In header
- 1 x S/PDIF Out header
- 2 x USB 2.0/1.1 headers
- 1 x IEEE 1394a header
- 1 x serial port header
- 1 x power LED header
- 1 x chassis intrusion header
- 1 x power switch
- 1 x reset switch
- 1 x clearing CMOS switch
Back Panel Connectors
- 1 x PS/2 mouse port
- 1 x PS/2 keyboard/mouse port
- 1 x optical S/PDIF Out connector
- 1 x coaxial S/PDIF Out connector
- 8 x USB 2.0/1.1 ports
- 2 x IEEE 1394a ports
- 2 x RJ-45 ports
- 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
- iTE IT8720 chip
H/W Monitoring
- System voltage detection
- CPU/System temperature detection
- CPU/System/Power fan speed detection
- CPU overheating warning
- CPU/System/Power fan fail warning
- CPU/System fan speed control
BIOS
- 2 x 8 Mbit flash
- Use of licensed AWARD BIOS
- Support for Dual BIOS™
- PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
- Support for @BIOS
- Support for Q-Flash
- Support for Download Center
- Support for Xpress Install
- Support for Xpress Recovery2
- Support for EasyTune
- Support for Dynamic Energy Saver Advanced
- Support for Time Repair
- Support for Q-Share
Bundle Software
- Norton Internet Security (OEM version)
Operating System
- Support for Microsoft/ Windows/ Vista/XP
Form Factor
- ATX Form Factor; 30.5cm x 24.4cm
• Dynamic Energy Saver Advanced is touted as the worlds only energy saving technology with hardware based 6-Gear switching. It does this by the use of VRD 11.1 allowing the DES to switch to Gear 1 phase when idle then immediately switch to Gear 6 when the need for ultra performance is required in turn allowing dramatic energy savings. So it can save energy, so what? Well thats not all because this is the advanced edition which works two-fold allowing overclockers to feel the benefit of phase power switching, providing stable power delivery to the CPU.
