Intel Core i9 10980XE and ASUS ROG Rampage VI Extreme Encore Review
Geekbench
Geekbench tests the single and multi-threaded performance of your system and is a good indicator of any weak spots, particularly if you’re overclocking.
In the multi-core test the Intel Core i9-10980XE gets really close to the Threadripper thanks it its bigger clock speed, and even at stock it’s comfortably ahead of the Core i9-9980XE. Like the Vegas result the Encore brackets the graph, with the Waterforce both a step ahead at stock and behind when overclocked.
