MSI X870E MPG Carbon WiFi Review
CPU Temperatures
CPU Temperatures
Our CPU temperature testing is a juxtaposition between best and worst case scenarios. We run a seriously heavyweight CPU cooler, which shows the best use case, and then torture the system for 30 minutes to get our peak reading. Otherwise known as the worst case scenario. The AMD Ryzen 9 9900X is a very good balance between extreme performance and relatively sane temperatures. It’s a mile ahead of the 14th Gen Intel offerings.
The MSI MPG X870E Carbon is the coolest of the seven motherboards we’ve reviewed for launch. As you’ll see in a couple of pages, it also puts the least voltage through our processor. Those two facts are not unrelated.
