Corsair GTX980 Ti Hydro GFX Graphics Card Review
Test Setup and Overclocking
Published: 15th November 2015 | Source: Corsair | Price: £619.99 |
Test Setup
Corsair Hydro GFX
Intel Core i7-4960X @ 4.4GHz
ASUS Rampage IV Extreme
Corsair Dominator Platinum 2133
Corsair AX1500i
Corsair Neutron GTX
Corsair H100i
Windows 7 x64
Overclocking
With so much cooling performance available to us it's easy to overclock the Hydro GFX and the results are spectacular. 1325MHz core speed and a whopping 1924MHz GDDR5 are further boosted by the nVidia GPU Boost 2.0 taking advantage of the thermal headroom to overclock the GM200 to a barely believable 1553MHz.
Or in fact any other brand? I'm guessing you weren't allowed to take the thing apart Tom? but did you notice anything that made the pump or mount look Original or modified to specifically fit this GPU?Quote
Is there anything (other than warranty) to stop you attaching any Corsair AIO?
Or in fact any other brand? I'm guessing you weren't allowed to take the thing apart Tom? but did you notice anything that made the pump or mount look Original or modified to specifically fit this GPU? |
Its just a pitty no-one has seen fit to do these Hybrid cards with 2*8pin power supplies and a dual bios.Quote
