be quiet! Light Mount and Dark Mount Keyboard Review
Light Mount Lighting
Getting your lighting exactly as you require is an understated task. Most of us just pick a colour and have all of it that way. There are more options though, and the be quiet! Light Mount provides you with a fair number of them. Obviously there are rainbow and single colour effects. Additionally the bar across the top is ARGB with over 40 separate ‘zones’. If that isn’t enough you can have per key lighting, and the software has multiple save options to ensure you can easily switch between them as needed.
It’s rare to see colours so bright both through the keycap and underneath, so forgive us if we give you a few pictures just to stare at.
If we had one slight critique it’s that the key colours are so beautiful, so richly saturated and accurate, that the light bar is somewhat lost in the shuffle. It’s a bit too white. Oddly, if you go for a uniform colour this problem is less pronounced.
