be quiet! Light Mount and Dark Mount Keyboard Review
Software
Software
be quiet! give you two ways to control the keyboard. You can use their software, much like every other manufacturer. It’s fully featured and covers everything they have to offer. Should you wish a faster, easier, or perhaps “I’m at a LAN party” solution, there is a browser based one too.
As you would expect, everything is under your fingertips. You can completely tailor the Dark Mount to your dark desires.
be quiet! have also provided you with plenty of default icons, so you don’t need to go digging around the internet for new icons. The keys are 140×140 px if you wanted to get really customised.
The media dock also let’s you control the lighting – and media – and the software can customise this even further if you wish. Including having your own idle graphic, should the be quiet! logo not be to your taste. Isn’t sticking our own name on things the first thing we all do when offered customisation options?
We always give a thumbs up to anyone who gives us the option to disable the Windows key in games. We’re sure there is a prank to be played/extra security to be had by disabling the Alt+Tab and Alt-F4 options and then loading a game that doesn’t have a quit button. Pal World for example. Granblue Rising for another. At least you could leave your computer knowing things are safe.
