Corsair K95 Platinum Speed Review
Lighting
With about a dozen different modes there is a lighting option to suit absolutely anyone, and this is before you have delved deeply into the heavily customisable personalised options, which give you nearly limitless control over keys, colours, the light bar – which is separated into sections for ultimate possibilities – and all the rest. Even the subtlest shades are well represented. In short, if you want to be able to do it, with the CUE software and the K95 Platinum, you can.
