Kingston H20 6GB 2000MHz DDR3 Review
SiSoft Sandra
SiSofts Sandra uses a different benchmarking memory method to AIDA64. It’s far more about purely testing the RAM than the underlying system.
As you can see yet again the Kingston HyperX H20 fails to cut the mustard. Sure the results aren’t epically bad, but as this is designed to run at 2000MHz it shouldn’t even be close.
wPrime 95
Finally we have wPrime95. It’s almost pouring salt into the wounds to mention the failure of the Kingston HyperX H20 again so let’s move on to the conclusion shall we.
