NZXT PSU Buyers Guide – Gold and Platinum Models
Cables
Cables
The NZXT PSU range supports both types of graphics card power natively. You have two 8pin PCIe for the AMD cards and certain Nvidia ones. The new 12V 2×6 ATX3 GPU power is there for the latest Nvidia graphics cards. Whichever you run, you’re covered.
We always enjoy having our PSU cables in a single bag. It just makes upgrades easier. The last thing you want to be doing is hunting through the box of loose cables we all own.
We can’t think of a single case where you’ll have it all plugged in, but it’s nice to show off the consistency of the cable design.
The early problems with the 12 pin power cable are largely solved. Just install it perfectly straight and ensure it’s fully inserted.
