Dune: Awakening PC Benchmark Performance Review
Benchmark Scenes
Dune Awakening PC Benchmark Scenes
Dune Awakening’s PC benchmark is split into three sections. First there is a Player Built Base. Next we have a Harkonnen village. Finally, there is a desert scene where a mighty sandworm emerges from Arrakis’ surface.
Finishing Dune Awakening’s benchmark will greet players with the following screen. This will detail the settings you used for your benchmark test, and the performance of the benchmark and each of its three areas.
These three scenes have different performance profiles. However, the player-built base scene is always the most demanding. This is especially true at lower resolutions. For this reason, we will use this test when comparing the performance of graphics cards later in this article.
At 4K, the “Player Built Bases” scene remains the most demanding. That said, the “Harko Village” has a similar performance profile at higher screen resolutions.
