Lian Li PC-O5S ITX Case Review
Up Close: Interior Rear of Motherboard
There actually appears to be more going on round the back than there is at the front of this case. Up in the top left corner, which is actually the front of the case there’s a bracket that can be used to hold a slim line Optical drive. If you’re not planning to use one, and need more storage then this bracket will also accept a single 3.5″ or 2.5″ drive.
Towards the base there’s yet another bracket for storage devices. This one can hold 1×3.5″ and 1×2.5″ or 2×2.5″ drives. Over to the left of it there’s the interior of the front I/O.
Although this is a slim case there’s plent of room for cable management, a good 36mm in fact which is excellent. Although there are no cable tie points as such, Lian Li have included several plastic cable management anchor points.
