Phanteks Enthoo Luxe Tempered Glass Review
Up Close: Interior Rear
How many wires? And that’s before we’ve started the build mind! Fortunately there’s oodles of room back here for cable manangement, so having all these fan cables and PCI power cables around isn’t an issue. There’s also plenty of pre installed hook-N-Loop fastenings, eight in total to kake taming those cables easier, along with more cable tie points than you can shake a stick at.
So how much room is there? Well how does 27mm grab you. If you can’t do a decent cabling job with these facilities and this amount of real estate on offer, you probably shouldn’t be allowed near sharp things unsupervised.
What we have here is a lovely little fan distribution hum, with a PWM header that can be taken to the motherboard or a fan controller.
How many 3.5″ drives? Seriously, in this day and age do we really need that many? At least they are removable, although doing so doesn’t make it that easy to get the alleged 240mm rad in there.
With the drive racks out the way, we can see into the area that is able to house up to a 240mm rad.
