Phanteks Enthoo Luxe Tempered Glass Review
Illumination
We just couldn’t get the white balance right on our images so decided to use some of Phanteks own to show the sumbtle illumination that the Luxe is capable of.
Although not offering full the full, almost infinate range of RGB colours, the Luxe does off three colour modes and 10 different colours. It’s also compatible with Phenteks LED strips so you can have everything glowing the same colour.
And should you be one of those that really likes to keep things coordinated you’ll be delighted to know that the Phanteks LED control can be used with Asus Aura and Other compatible RGB motherboards
