DFI X48 UT-T3RS Motherboard
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The “Long bench” was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Results Conclusions
It is apparent that the Intel chipsets are still a little behind the NVidia chipsets when HD performance is concerned, although the gap has closed somewhat of late. Having said that the DFI can still holds its own in this department scoring well across the range of tests.
