HIS HD6990 Eyefinity 5760×1080 Review
We have something a little special for you today.
With the recent influx of exceptionally high-end GPUs such as the HIS HD6990 on test today, and the GTX590 it’s clear that even a 1920×1200 single screen really isn’t doing justice to the cards and their abilities.
What we really needed was a triple screen setup to push them hard and test them in the way they’re designed.
Thankfully, courtesy of Iiyama, we now have three screens to run these cards at a massive 5760×1080 resolution, which is what we’re doing today for the HIS HD6990, and over the coming weeks we’ll go back and look at the other high-end solutions and see how they fare.
It’s a monster of a review that’s taken an age to put together, so without further ado let’s crack on.
Technical Specifications
The HIS Digital HD6990 is a reference style card running at the standard 830 MHz. A whopping 4GB of GDDR5 ensures that even in Eyefinity mode the card shouldn’t run out of frame buffer.
| Product Code | H699F4G4M |
| EAN Code | 4895139005387 |
| Cooler | Fan |
| GPU | 6990 |
| Core Clock | 830 MHz |
| Memory Clock |
5000 MHz |
| Memory Size | 4096 MB |
| Memory Type | GDDR5 |
| Memory Interface | 256 bit |
| Interface | PCI Express x16 (PCI Express 2.1) |
| Card Dimension | 12.8 x 4.2 x 32 cm cm (HxWxD) |
| Box Dimension | 37.8 x 9.45 x 15.25 cm cm (HxWxD) |
