Steelseries Apex 7 Keyboard Review
Lighting
The lighting on the Apex 7 is up to Steelseries usual high standards with uniform colouring across all the keys, and smooth gradients. If you’re wondering about the Num lock light, the lock indicators are built into the keys and so will show white when they are on but otherwise, as you can see from the Caps lock, match your colour choice. A clever solution.
