Steelseries Apex 7 Keyboard Review
OLED Display
Pretty much all the features you can adjust from the Steelseries Engine software you can also control on the keyboard itself using the built in menu on the OLED – Organic Light Emitting Diode – display. A long press on the main button brings it up and then you use the scroll wheel to cycle through your options, clicking the wheel for okay or hitting the main button for cancel. It’s a very simple solution to the otherwise esoteric combination of keys and blinking lights that usually accompany onboard keyboard setup systems. Plus when you’re not using it to control the keyboard you can use it to show which song you’re playing, or your volume, or some cool cat gif.
