Destiny 2 Beta PC Performance Review
4K Performance
4K is the only resolution where we started to struggle to achieve steady 60+FPS framerates, with every GPU tested requiring lower settings or a lower resolution scale.
Those that are satisfied with 30FPS gameplay, the same framerate as the console version, will be happy to know that even the lowly GTX 1060 Strix is able to achieve this at high settings, though some higher-end hardware is required for a constant 60+ FPS at 4K High settings.
It seems likely that a GTX 1080 Ti would be able to play this game at a constant 60+ FPS at these settings, though sadly we do not have that GPU on hand to test in Destiny 2 to confirm this.
