3XS RTX Studio Pro System Review
Why a RTX 4090?
Why a RTX 4090?
We understand there might be a little bit of confusion regarding the 3XS RTX Studio Pro specifications. After all, if the key audience are creators, a “Pro Graphics” system, why use the flagship GPU when you’ve the flagship Intel CPU? The answer, of course, is easy. If you’ve never experienced the calculative power of a CUDA setup prepare to be amazed. For example, here is Cinebench R24, a very stern test, using each. 2085 points on the Core i9-14900K is no slouch, but the ASUS TUF RTX 4090 gives us 34717.
Therein lies the answer to your question. Leverage that compute power and save yourself masses of time.
If numbers are a bit too nebulous, then time is better. To render our OC3D custom blend at 4K takes nearly 9 minutes on the Core i9-14900K. If you move the rendering to the CUDA cores available on the RTX 4090, that’s slashed to 45 seconds. You don’t need us to tell you that time is money. If you rendered a minute-long 24 FPS 4K short film it would take 18 hours on the RTX 4090 CUDA cores and 211 hours on the CPU. Exactly.
