3XS RTX Studio Pro System Review
Subtlety
Subtlety
We spoke on the previous page about the lack of RGB on the fans. In fact here is everything that lights up in the 3XS RTX Studio Pro lit up.
This lightbar within the centre of the pump is configurable. You can use it to give you an at-a-glance report on fan speeds, temperatures, even memory utilisation. It’s very useful.
When you’re editing video you need the colours to be as accurate as possible. Something that would be distracting is a case that is doing its best impression of an Olympic opening ceremony. By going for the very minimum of lighting in the case you’re free to concentrate upon your screen. You could even turn the TUF logo off on the RTX 4090 if you really wanted to go full stealth.
