Tryx Panorama 360 SE AIO Review
Test Setup and Temperatures
Normally the coolers get tested on our standard Core i5-14600 rig. Naturally as this is primarily a replacement/refresh for the Bengal Rig, instead it’s going to be tested on my Core i7-13700K and compared against the other three coolers I’ve had bolted to this CPU. Initially the orange beast was built with the EK Nucleus CR360. When that died – my system is on every minute I’m awake – the MSI I360 was used as a temporary stop gap, but long enough to get tested. I’ve used three speeds, 40% – usually the fan noise tipping point, after which they’re audible, 75% for beefy cooling without going deaf, and 100% for testing the upper cooling limit.
Cooler : Tryx Panorama 360 SE
Case : Cooler Master SL600M
Motherboard : Gigabyte Z790 Aorus Master X
CPU : Intel Core i7-13700K
GPU : Palit RTX 4090 Game Rock OC
Memory : XPG Lancer Blade RGB DDR5 6000MHz 32GB
PSU : Cooler Master V1300 SFX Platinum
The Tryx Panorama is unbelievably good. We know the MSI is a great affordable option, and the EK Nucleus is one of the best we’ve ever tested. Clearly the ASETEK pump and radiator combination work miracles. So much so it should be capable of cooling any processor you can to install it upon.
