MSI Big Bang Marshal P67 Review
3D Mark
Published: 28th March 2011 | Source: MSI | Price: |
3D Mark Vantage
Both versions of 3D Mark are highly reliant upon the quality of the GPU rather than the motherboard, so we run the testing just to make certain that everything is as it should be and there aren't any unexpected glitches. With the excellent quality of the MSI manufacturing process it's no surprise at all that the scores are exactly where we'd hope they'd be.
3D Mark 11
Naturally despite the testing methodology of 3D Mark 11 being very different from Vantage, the results are the same for our purposes. Namely the MSI Big Bang Marshal is right where we'd expect with no nasty surprises awaiting you.
Anyway that's an amazing board, one thing with the technical specs, it says it can't run 3 way SLI, so if you want to fill up all the slots you're pretty much stuck with AMD?Quote
Excellent review as always. Anyway that's an amazing board, one thing with the technical specs, it says it can't run 3 way SLI, so if you want to fill up all the slots you're pretty much stuck with AMD? |
