Agents of Mayhem PC Performance Review
1080p Performance
In our GPU performance comparison, we decided to test the game using Agents of Mayhem’s High graphical preset, as it offered a great balance between graphical fidelity and performance. To say the least Agents of Mayhem’s high preset is demanding enough for our testing needs and it doesn’t use Nvidia HTFS by default, which we have found to cripple the performance of AMD GPUs.
In our test scenario, we found that only our GTX 1080 was able to achieve a steady 60+FPS. Framerates will also be higher in the game when there is no direct sunlight, so thankfully a large portion of the game will be significantly easier to run.
