Agents of Mayhem PC Performance Review
Graphical Options and Settings
To start off we experienced some bugs when messing with Agents of Mayhem’s graphical options menu, especially when it came to setting applying when we started a new session of this game. When starting the game, Agents of Mayhem often would boot in Windowed mode, rather than the fullscreen mode that we specifically selected. This can be easily fixed in the game, but it becomes a chore when it needs to be done upon every startup.
Agents of Mayhem contains the usual options like resolution, screen refresh rate, frame rate caps, graphical presets, v-sync options and even colour blind options. There is also a VRAM usage bar at the side, which is exclusive to Nvidia GPU users.
Below is a list of all of the graphical options that are available under Agents of Mayhem’s advanced graphical options menu.
Note that Nvidia TXAA and FXAA are enabled by default on all graphical presets and that Nvidia Volumetric lighting, a Nvidia only option is enabled when the game is played at Ultra settings on Nvidia hardware. On AMD hardware this option stays at Screenspace levels at Ultra.
| Settings | Low | Medium | High | Ultra |
| Motion Blur | Disabled | Enabled | Enabled | Enabled |
| Depth of Field | Disabled | Enabled | Enabled | Enabled |
| FXAA | Enabled | Enabled | Enabled | Enabled |
| TXAA | Enabled | Enabled | Enabled | Enabled |
| Scene Detail | Low | Medium | High | High |
| Shadow Quality | Low | Medium | Medum | High |
| Sun Shadows | Normal | Normal | Nvidia PCSS PLUS | Nvidia HFTS |
| God Rays | Disabled | Screenspace | Screenspace | Nvidia Volumetric |
| Effects Quality | Normal | High | High | High |
| Texture Cache Size | Low | Normal | Normal | High |
| Filter Quality | Trilinear | Anisotropic 4X | Anisotropic 12x | Anisotropic 16X |
| General Reflections | Normal | Normal | High | High |
| Planar Reflections | Normal | Normal | Normal | High |
| Screen Space Reflection | Disabled | Disabled | Disabled | Enabled |
| Edge Treatment | Disabled | Enabled | Enabled | Enabled |
| HBAO | Disabled | Enabled | Enabled | Enabled |
