Yakuza Kiwami 2 PC Performance Review
PC System Requirements
As a 900p 30FPS title on PlayStation 4, we know from the outset that Yakuza Kiwami 2 is going to be a challenging game to run on PC. 1080p already offers a 44% increase in pixel count over 900P and bumping that up from 30FPS to 60FPS will require an additional 100% increase in system performance.
In short, 1080p 60FPS gameplay won’t be a walk in the park for Yakuza Kiwami, but thankfully modern PC hardware has long surpassed what today’s base level consoles can offer. That said, cranking this game up to 4K is going to be a tough prospect.
MINIMUM:
OS: Windows 7 (64-Bit Required)
Processor: Intel Core i5-3470, 3.2 GHz / AMD Ryzen 3 1200, 3.1 GHz
Memory: 4 GB RAM
Graphics: GeForce GTX 660, 2 GB / Radeon HD 7870, 2 GB
DirectX: Version 11
Storage: 42 GB available space
Additional Notes: Pre-set Graphics Setting: Low, Target FPS: 30FPS (1080p at 75% render scale)
RECOMMENDED:
OS: Windows 10 (64-Bit Required)
Processor: Intel Core i7-6700, 3.4 GHz / AMD Ryzen 7 1700, 3.7 GHz
Memory: 16 GB RAM
Graphics: GeForce GTX 1070, 8 GB / Radeon RX Vega 56, 8GB
DirectX: Version 11
Additional Notes: Pre-set Graphics Setting: High, Target FPS: 60FPS @1080p
Drivers
When testing Yakuza Kiwami 2, we opted to use the newest drivers from both the Radeon and Geforce camps, utilising AMD’s Radeon Software Adrenalin Edition 19.4.3 driver as well as Nvidia’s Geforce 430.64 driver.
Testing Methodology
OC3D is a website that is dedicated to PC hardware, so you better believe that we test every game on a wide range of hardware configurations. This commitment to variety means that we will be using both Intel and AMD based testbeds as well as a range of GPU offerings from both Nvidia and Radeon.
Our primary test system uses Intel’s X99 platform, containing an Intel Core i7 6850K at a fixed clock speed of 4GHz. This testbed will use 32GB of Corsair Vengeance DDR4 memory and will be powered and cooled by an HX1200i PSU and an H110i AIO liquid cooler respectively, with everything sitting inside a Corsair 460X chassis. In this system, we are using an ASUS Strix X99 motherboard.
The system below will be used to conduct the majority of our game testing. This system will be used in this review unless otherwise stated.
Game Test Rig
Intel i7 6850K @4.0 GHz
ASUS X99 Strix
Corsair Vengeance LP 4x8GB DDR4 3200MHz
Corsair HX1200i
Corsair H110i GT
Windows 10 x64 “October 2018 Update”
Secondary Ryzen Test System
Aside from our standard X99 test system we also have a testbed based on AMD’s Ryzen 7 1700X CPU, which will sit at a clock speed of 4GHz be housed in an ASUS Crosshair VI Hero motherboard. This system will use Corsair’s 3200MHz Vengeance White LED memory and is contained inside another Corsair 460X chassis.
This additional system will allow us to see if any games offer a performance advantage to AMD’s Ryzen or Intel’s Core series processors.
AMD Ryzen Game Test Rig
AMD Ryzen 7 1700X @ 4.0GHz
ASUS X370 Crosshair VI Hero
Corsair Vengeance LED 2x8GB DDR4 3200MHz
Corsair 460X System Chassis
Corsair RMi650
Corsair H115i
Nvidia GTX 1080 Founders Edition
GPU Selection
No gaming test suite would be complete without a large selection of GPUs, which in this case covers Nvidia’s RTX 20-series GTX 10-series and 9-series and AMD’s RX Vega, RX 400 and R9 300 series graphics cards. We have replaced our RX 480 GPU with its RX 580 equivalent, giving us a fairer comparison point between AMD/Nvidia’s modern graphics card lineups.
Starting with Metro Exodus, we will be testing new PC games with Nvidia’s latest RTX series of graphics cards, with the mid-range RTX 2060 and high-end RTX 2080 Ti entering our graphics card lineup.
Geforce RTX 20-Series
– Nvidia RTX 2080 Ti Founders Edition
– Nvidia RTX 2060 Founders Edition
Geforce GTX 10-series
– Nvidia GTX 1080 Founders Edition
– Nvidia GTX 1070 Founders Edition
– ASUS GTX 1060 Strix Gaming OC
Geforce GTX 900-series
– ASUS GTX 960 Strix
AMD RX Vega Series
– AMD RX Vega 56
AMD RX 500 Series
– AMD RX 580 Strix OC
AMD GCN GPUs
– ASUS R9 380 Strix
Keyboard & Mouse
To control this setup, we will be using Corsair Strafe RGB keyboard with Cherry MX Silent keys alongside a Corsair M65 RGB mouse, matching the general theme of this RGB illuminated system.
Cherry MX Silent Keys are ideal for gaming, coming with similar characteristics as Cherry MX Red keys, but with quieter operation. This comparative silence will help keep players immersed in their games, without the distracting clicks that are present in other Cherry key switches.
