Prey PC Performance Review
Graphical settings tweaks
FoV Options
Prey lacks several key graphical options at launch, but thankfully you can adjust these using the game’s game.cfg files. This will allow fans of wide FOVs and a lack of motion blur to modify their game to their liking, with the game supporting FoV values of up to 120.
To edit Prey’s FoV and motion blur settings you will need to navigate to C:Users(YourUserName)Saved GamesArkane Studios on your PC and open a file called game.cfg. Inside this file, you can edit a setting called cl_hfov = 85.5656, which will allow users to edit the game’s FoV.
Below is an example edit that will change your FoV to 120 degrees.
cl_hfov = 120
Motion Blur
To disable motion blur, you must add a new line to Prey’s game.cfg file which is called r_motionblur = 0 which will remove the game’s default Motion Blur option.
Remove 144Hz FPS Cap
Inside Prey’s game.cfg file, find a line called sys_MaxFPS and change the value to whatever you wish the game’s framerate limit to be. Below is an example for an effectively unlimited framerate.
sys_MaxFPS = 999
Skip Intro Movies
Inside your game’s installation folder, navigate to GameSDKVideos and delete the following files;
– ArkaneLogoAnim_Redux_1080p2997_ST-16LUFS.bk2
– Bethesda_logo_anim_white.bk2
– LegalScreens.bk2
– Ryzen_Bumper.bk2
This will speed up your game’s initial load times significantly.
