Far Cry 5 PC Performance Review
1440p Benchmarks
Moving up to 1440p pretty much confirms our suspicions at 1080p, with the minimum framerates on both our RX Vega 56 and GTX 1080 lowering by a mere 8 and 15FPS respectively, while the GTX 1070 seen a reduction of a much larger 22FPS. This data again leads us to believe that there is a CPU limitation at work here, though it only seems to be an issue when our framerates are well above 60FPS.
At 1440p we can see that anything above a GTX 1070 can offer an average framerate of over 60FPS, with the GTX 1070 only seeing minor dips below that mark. Again our RX Vega 56 and GTX 1080 Founders Edition GPUs offer nigh identical performance, showcasing the power that Rapid Packed Math has to propel AMD’s GTX 1070/Ti competitor to similar performance levels to Nvidia’s higher-end model.
At Ultra settings Nvidia’s GTX 1080 and AMD RX Vega 56 can achieve a stable 60 FPS in our tests, though it is likely that a GTX 1070 Ti or an overclocked GTX 1070 could also surpass this performance target.
